Hi all,
I am trying to connect a SDP810-500 differential I2C pressure sensor to a Pixhawk 3 for a scientific work.
I adapted the existing Airspeed_SDP3X files and created a new Airspeed_SDP810 file.
The problem is that the sensor seems not to be recognized.
- The sensor was successfully tested with my own AVR-Library
- The address was changed to 0x25
- The sensor is correctly connected via I2C to my Pixhawk (other differential pressure sensor works, swap SCL and SDA did not help also)
- I tried to change the address of the existing Airspeed_SDP3X file with no success (same problem: init is already left after trying to send “CONT_MEAS_STOP”)
- The init routine is called (verified via UART)
- The “CONT_MEAS_STOP” command cannot be sent and the “CONT_MEAS_AVG_MODE” command also
- I tried connecting the sensor with and without pullups at SDA/SCL lines
- No errors or warnings at the compiler
My init-code is the following:
bool AP_Airspeed_SDP810::init()
{hal.console->printf(“SDP810 INIT\n”);
const uint8_t address = SDP810_I2C_ADDR;
bool ret = false;_dev = hal.i2c_mgr->get_device(get_bus(), address);
// lots of retries during probe
_dev->set_retries(10);hal.console->printf(“STAGE: 1\n”);
// stop continuous average mode
if (!_send_command(SDP810_CONT_MEAS_STOP)) {
_dev->get_semaphore()->give();
return false;
}hal.console->printf(“STAGE: 2\n”);
// these delays are needed for reliable operation
hal.scheduler->delay_microseconds(20000);// start continuous average mode
if (!_send_command(SDP810_CONT_MEAS_AVG_MODE)) {
return false;
}hal.console->printf(“STAGE: 3\n”);
hal.scheduler->delay_microseconds(20000);// step 3 - get scale
uint8_t val[9];
ret = _dev->transfer(nullptr, 0, &val[0], sizeof(val));
if (!ret) {
return false;
}hal.console->printf(“STAGE: 4\n”);
// Check the CRC
if (!_crc(&val[0], 2, val[2]) || !_crc(&val[3], 2, val[5]) || !_crc(&val[6], 2, val[8])) {
return false;
}hal.console->printf(“STAGE: 5\n”);
_scale = (((uint16_t)val[6]) << 8) | val[7];
hal.console->printf(“SDP810: Found on bus %u address 0x%02x scale=%u\n”, get_bus(), address, _scale);
hal.console->printf(“STAGE: 6\n”);
this sensor uses zero offset and skips cal
set_use_zero_offset();
set_skip_cal();
set_offset(0);// drop to 2 retries for runtime
_dev->set_retries(2);_dev->register_periodic_callback(20000, FUNCTOR_BIND_MEMBER(&AP_Airspeed_SDP810::_timer, void));
return true;
UART shows “SDP810 INIT” and “STAGE: 1” but nothing more so I think the I2C communication to the sensor is not working.
I only have a few weeks ArduPilot experience, so I would appreciate help from someone more experienced which may find the cause of this problem.
Thank you in advance!
