There is already a similar article, but it failed to get an answer, so I decided to create a new one.
I use Matek H743 and fw 4.3.7 need the aircraft to automatically descend at an angle of 30% along the slope, but I could not find the parameters responsible for this.
The WP_NAV_ANGLE parameter is not in the list of parameters, perhaps I need to include something to display it? or use an additional script? or is the parameter I need called differently? I would be extremely grateful for any ideas. I will attach the file with the parameters a little later.
I create a route in the mission planner based on the absolute altitude and the planner sets the altitude itself, after creating the mission, the distance and angle between the points can be seen, which is about -30 degrees, however, in fact, when performing the march, the maximum angle of inclination does not exceed -10 degrees.
LIM_PITCH_MIN is set to more than -30 degrees and it is only responsible for flight in stabilization modes.
And I will study the parameters of TESS in more detail, I will not give up specifics.
