I can't change radio mode or reverse
I use a F405 SpeedyBee Wing
I use Apm Planeur 2.0.30-rc1 on my Mac. ( On windows it’s rc3 ).
I try the laster version 4.4.5 ? ( it’s just write “lasted” ). I try the 4.4.4
My radio is Tango 2 Crossfire, in mode 1.
I want to put mode 1, but, there is not “write”, so it doesn’t change.
Reverse to…
Calibration to …
The the video https://www.facebook.com/100000553126713/videos/374224455436596/
Thank you
And I don’t want to find patches by changing my radio from mode 1 to 2, (because that will change all my models) or holding it upside down!!! There is a page in the application and it doesn’t work!
THANKS
tbh I am not entirely sure what you are trying to achieve, as long as your transmitter sends the channels in the correct order (default AETR), Mission Planner/ArduCopter absolutely do not care what mode your transmitter is in.
Even if your transmitter sends the channels in a different order, you can change it in Mission Planner with the RCMAP_PITCH, RCMAP_ROLL, RCMAP_THROTTLE and RCMAP_YAW parameters where you can define the channel for each individually (even outside 1-4).
After long hesitation to click on a “facebook” link, it turns our your video is private (or at least private enough that I can’t access it).
Please don’t yell, has anyone suggested that (yet)? It surely would look funny though.
Thank you for all !!!
So the page for change mode it’s doen’t work :
But with your parameter it’s ok !!
Thank you
This is my plane : :Redirecting...
Great to hear it worked :+1:t2:
That actually looks really nice and like a lot of work has been put into it :sweat_smile:
Especially that gimbal mechanism for the camera looks great and compact :+1:t2:
