Can i change the orientation of the modes. my rc is mode 1, the right stick is not spring loaded.
Left one is auto centered and I thought it is more eligible . what do you say?
Physically switch the radio to mode 2. Sounds like you should have bought a mode 2 radio in the 1st place.
Yes definitely. I didn’t even know about the mode stuff and truth be told I was shy to ask about it when i was ordering it. Being a total newbie is a challenge
Thanks for the helps.
Btw for the 2 axis gimball i think i should make a parallel connection of ground and 5V lines bec from esc and connect them to servo relay. And plug the signal and ground servos to the 1st and 2nd outs of pixhawk. Is it correct?
The power connection for the gimbal servos sound good. For Pixhawk outputs you probably want to use Aux 1&2. What will you use for control of these on your radio? It looks like there are 2 pots you could use. Is this just for manual control of pitch and pan?
hi, I want to use them for the gimball so the pixhawk should control the servos to stabilize the camera. Rn I’m trying to get the gps data to odroid xu4
Then set it up on the Camera Gimball screen in Mission Planner.
I did however its natural position is wrong
