Hello everyone,
I am quite new to ardupilot. I had a couple of successful flights so far. But today wasn’t a lucky one and I managed crash land the plane.
Here are the relevant bits.
The highlighted area is a sharp turn. After that, the plane starts to drop.
But it didn’t look a stall drop. Usually a stall drop is more sudden and is followed by a quick recovery.
This one was more like the plane was going down relatively slow compared to stall situations that I simulated in the past on the same plane at high altitude.
And I think it had quite some time to recover considering it was full throttle all the time.
One wierd thing - the gps alt has a lag compared to baro. In previous flights the gps altitude follows closely the baro altitude.
Indeed this could be a stall. But maybe there is something else that I missed by looking at the logs.
These are my logs https://drive.google.com/file/d/1enxsPzr3BFoMGD9XZr3ktu33ivjhWBSj/view?usp=sharing
For the record:
Model - 1.8m glider with V-tail and pusher prop mounted at the rear
RCOU configuration - C4 aieron, C5 vtailLeft, C6 vtailRight, C8 ESC
Thank you for your help!
Liviu
