I am working with MATEK L431 CAN Node for one of the projects. I have tested with a single rangefinder through CAN Node.
Can anyone please help me to integrate two rangefinders in a single node?
Thank You
Thank You
I am trying to connect an LW20/C via Matek L431 CAN Node.
Would you like to share your hardware and software (ardupilot parameters and CAN Node settings) configuration?
Thanks!
First you need to change the CAN NODE firmware…
Only then rangefinder parameters will appear.
Firmware file for MATEK L431:
AP_Periph.bin (126.4 KB)
Yeah, I uploaded firmware for rangefinder.
Still not getting any results
Lidar is connected to serial 2 (pins on the side of the board, not the connector)
Known issue, not yet fixed
My LW20 is on its way after a repair from Lightware. I can figure out the issue once its here.
