OK, so I broke this the other day with a commit which added a compiler
sanity check which the gtest suite fails. I’ll be patching that in the
next day or so.
In the meantime, the addition step you need to take is to comment out the
addition of -Werror=suggest-overrides in Tools/ardupilotwaf/boards.py
Past that, this is how you run the gtests:
./waf configure --board=linux
./waf tests
ls ./build/linux/tests/
pbarker@bluebottle:~/rc/ardupilot(master)$ build/linux/tests/test_math
[==========] Running 10 tests from 3 test cases.
[----------] Global test environment set-up.
[----------] 1 test from VectorTest
[ RUN ] VectorTest.Rotations
[ OK ] VectorTest.Rotations (0 ms)
[----------] 1 test from VectorTest (0 ms total)
[----------] 5 tests from MathTest
[ RUN ] MathTest.IsZero
[ OK ] MathTest.IsZero (0 ms)
[ RUN ] MathTest.IsEqual
[ OK ] MathTest.IsEqual (0 ms)
[ RUN ] MathTest.Square
[ OK ] MathTest.Square (0 ms)
[ RUN ] MathTest.Norm
[ OK ] MathTest.Norm (0 ms)
[ RUN ] MathTest.Constrain
[ OK ] MathTest.Constrain (0 ms)
[----------] 5 tests from MathTest (0 ms total)
[----------] 4 tests from MathWrapTest
[ RUN ] MathWrapTest.Angle180
[ OK ] MathWrapTest.Angle180 (0 ms)
[ RUN ] MathWrapTest.Angle360
[ OK ] MathWrapTest.Angle360 (1 ms)
[ RUN ] MathWrapTest.AnglePI
[ OK ] MathWrapTest.AnglePI (0 ms)
[ RUN ] MathWrapTest.Angle2PI
[ OK ] MathWrapTest.Angle2PI (0 ms)
[----------] 4 tests from MathWrapTest (1 ms total)
[----------] Global test environment tear-down
[==========] 10 tests from 3 test cases ran. (1 ms total)
[ PASSED ] 10 tests.
Just to complement: you can use waf to run the tests: ./waf check (which runs all tests that haven’t run or have failed before) or ./waf check-all (which always runs all tests).
