Hi ,
I would like to trigger a relay whenever my rover covers a certain distance (like 3meter)?
I would like to get suggestions about the best way to approach this task
thanks in advance
You can set your relay as a camera trigger, then in a mission add an item with do set cam trigger distance and set the corresponding field to 3m. Now:
A. Use can use it in a mission or
B. just change the trigger distance param, to use it in all other modes
Presequites:
You need to set the relative cam_ parameters for the relay state (High, Low) and Trigger time, to fit it for your needs.
Best,
D
