How to simulate a swarm of quadopters using ardupilot_sitl_gazebo_plugin?
Hi Everyone,
I am trying to simulate a group of UAVs using the ardupilot in gazebo. So far I have been able to actually bring up two different instances of the erlecopter in gazebo but I keep getting the same message:
ARI: Cannot receive input from Ardu, for the port is not open !
as for that I also show my launch file for two copters
<?xml version='1.0'?>
<launch>
   <!-- start world -->
  <arg name="simRate" default="nan"/>
  <!-- Enable simulation clock -->
  <param name="use_sim_time" type="bool" value="true" />
  <arg name="world_name" default="$(find multi_uav)/worlds/empty.world" />
  <arg name="gui" value="true" />
  <arg name="headless" value="false" />
  <env name="GAZEBO_MODEL_PATH" value="$(find ardupilot_sitl_gazebo_plugin)/meshes/meshes_sensors"/>
<!--<env name="GAZEBO_MODEL_PATH" value="$(find drcsim_model_resources)/gazebo_models/environments:$(find ardupilot_sitl_gazebo_plugin)/meshes/meshes_sensors:$(find ardupilot_sitl_gazebo_plugin)/meshes/meshes_outdoor:$(find ardupilot_sitl_gazebo_plugin)/meshes/meshes_warehouse"/>
<group ns="uav">
	<arg name="namespace" value="uav"/>
	<arg name="enable_logging" default="true"/>
        <arg name="enable_ground_truth" default="true"/>
	<arg name="log_file" default="erlecopter1"/>
	<include file="$(find mavros)/launch/apm_sitl.launch" >
		<arg name="fcu_url" value="tcp://localhost:5760" />
		<arg name="gcs_url" value="udp://:14550@" />
		<arg name="tgt_system" value="1" />
		<arg name="tgt_component" value="1" />
	</include>
  	<arg name="name" default="erlecopter1"/>
  	<arg name="model" default="$(find ardupilot_sitl_gazebo_plugin)/urdf/erlecopter_base.xacro"/>
  	<arg name="tf_prefix" default="$(arg namespace)"/>
  	<arg name="debug" default="true"/>
  	<arg name="verbose" default="true"/>
  <!-- Initial pose for the drone -->
  	<arg name="x" default="0.0"/> <!-- [m], positive to the North -->
  	<arg name="y" default="0.0"/> <!-- [m], negative to the East -->
  	<arg name="z" default="0.08"/> <!-- [m], positive Up -->
  	<arg name="roll" default="0"/> <!-- [rad] -->
  	<arg name="pitch" default="0"/> <!-- [rad] -->
  	<arg name="yaw" default="3.1415"/> <!-- [rad], negative clockwise -->
  <!-- send the robot XML to param server -->
  	<param name="robot_description" command="
    $(find xacro)/xacro --inorder '$(arg model)'
    enable_logging:=$(arg enable_logging)
    enable_ground_truth:=$(arg enable_ground_truth)
    log_file:=$(arg log_file)
    nspace:=$(arg namespace)"
  	<param name="tf_prefix" type="string" value="$(arg tf_prefix)" />
  <!-- push robot_description to factory and spawn robot in gazebo -->
  	<node name="spawn_erlecopter" pkg="gazebo_ros" type="spawn_model"
   args="-param robot_description
         -urdf
         -x $(arg x)
         -y $(arg y)
         -z $(arg z)
         -R $(arg roll)
         -P $(arg pitch)
         -Y $(arg yaw)
         -model $(arg name)"
   respawn="false" output="screen" >
  	</node>
	<node pkg="robot_state_publisher" type="robot_state_publisher" name="robot_state_publisher" output="screen"/>
	<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" output="screen"/>
</group>
<group ns="uav2">
	<arg name="namespace" value="uav2"/>
		<arg name="fcu_url" value="tcp://127.0.0.1:5770" />
		<arg name="gcs_url" value="udp://:14560@" />
	</include>
  	<arg name="name" default="erlecopter2"/>
  	<arg name="y" default="1.0"/> <!-- [m], negative to the East -->
         -urdf
         -x $(arg x)
         -y $(arg y)
         -z $(arg z)
         -R $(arg roll)
         -P $(arg pitch)
         -Y $(arg yaw)
         -model $(arg name)"
  	</node>
</group>
<include file="$(find multi_uav)/launch/empty_world.launch">
    <arg name="paused" value="true"/>
    <arg name="headless" value="$(arg headless)"/>
    <arg name="gui" value="$(arg gui)"/>
    <arg name="world_name" value="$(arg world_name)"/>
  </include>
</launch>
I also should note that in the world file I’m doing (which I think might be the issue)
<plugin name="ardupilot_sitl_gazebo_plugin_1" filename="libardupilot_sitl_gazebo_plugin.so">
	<UAV_MODEL>uav/erlecopter</UAV_MODEL>
</plugin>
<plugin name="ardupilot_sitl_gazebo_plugin_2" filename="libardupilot_sitl_gazebo_plugin.so">
	<UAV_MODEL>uav2/erlecopter</UAV_MODEL>
I was hoping someone on this forum, could help me. I also upload two images of the corresponding mavproxy instances I have at startup
If you need any more details let me know (I’m running Ubuntu 16.04 LTS and ROS kinetic.
Thank you all very much,
Hugo
did you solve this problem?
is tcp://localhost:5760 and 5770 is the right address to configure?
There were a couple of things that needed to be changed:
the first was to make some changes to the ardupilot_gazebo_plugin
you can find these here:
inside each group tag you should call mavros as follows:
	<arg name="fcu_url" value="udp://127.0.0.1:14551@" />
	<arg name="gcs_url" value="" />
changing the “51” to “61” for the second drone and adding +10 form that onward. Also in the world file, because the ports need to be specified, you should call it like
<PORT_NO>9002</PORT_NO>
<PORT_OUT>9003</PORT_OUT>
</plugin>
  <PORT_NO>9012</PORT_NO>
  <PORT_OUT>9013</PORT_OUT>
</plugin>
adding +10 to each port with the increasing number of uavs. Also of note, I do not use the vehicle.sh, but the vehicle.py from the original ardupilot source here:
git://github.com/ArduPilot/ardupilot.git
hope this helps.
Cheers,
Hugo
