How to setup AM32 ESCwith arduplane?
Don’t give too much about the EDT values.
I’m using the AM32 Wraith32 2.16 FW on the Holybro ESC on a plane with arduplane and on a quad copter with betaflight.
I get plausible RPM on the plane while Current and Temperature are not plausible.
This is likely caused by using the same design based firmware for different hw, so the scaling is not valid. I’m not sure If I purchased fakes for the Copter but one ESC on copter tells me twice the temperature the others tell and the RGB Leds dim out in different colours, 2 white, one green, one red.
Hi there, I’m also trying to get AM32 telemetry to work with Arduplane.
I have a single Sequre 2670 FW 2.16 controlled with PWM (no BDshot), and it’s outputting plausible data on its Tx line:
I connected it to Serialn_Rx and set protocol to ESC telemetry, but can’t any nonzero value in Mission Planner. Is my expectation right to see esc telemetry once a connected ESC sends telemetry data to a serial rx port?
