How to set RC switch to control forward or backward
Hi
Right now I can control my Rover forward and backward.
And I fly copter with the same RC controller. So I want to use the throttle the same way as copter does.
Is there any way to set a RC switch properly?
a) switch off (default), throttle up from the bottom, speed up and move forward
b) switch on, throttle up from the bottom, speed up and move backward
Any idea?
It seems with RC mix function, it will do.
But I still didnโ€™t get my TX12 works. :frowning:
Thatโ€™s how I have had my Rovers setup with a very simple mix on the Transmitter.
Switch SD is obviously forward/reverse. Nothing to it.
thr mix
TX12(OpenTX) Thr + SB, @dkemxr Thanks, it works :slight_smile:
  • Forward
  • Backward
