Hi . I hope you are well. I complete my flight safely.
But the camera did not capture not even one picture.
What i can do to resolve this problem. Something with settings configure.
My camera is not on the list of mission planner. I am using SAMSUNG smart camera, NX1100 , 20-50mm Kit. ### 20.3 MegaPixels.
Is the a function to set for auto capture. In mission planner i saw i programmed 20pictures to be taken.
YOUR ASSISTANCE WOULD BE GREATLY APPRECIATED
Which Flight controller are you using? How is your camera connected to the flight controller?
Futaba 10JI , Hexacopter drone connected with usb cable. camera SMART SAMSUNG NX1100.
ONE THE RC CONTROLLER WHICH KEY WILL BE FOR CAPTURE
The default configuration does not have a camera trigger setup. You will need to map a switch on your transmitter (futaba 10j) to the camera shutter command. You can make any switch you want trigger the camera shutter.
The wiki covers camera shutter trigger setup:
http://ardupilot.org/copter/docs/common-camera-shutter-with-servo.html
OKAY THANK YOU I WILL TRY IT, TOMORROW .
for futaba i will research again about it
I don’t understand the AUX BECAUSE MY DRONE IS NOT WRITTEN . HOW CAN I I IDENTIFY THE AUX, SERVO , RC connection for the settings.
CH7 does not have details for the camera setting, how can i choose another channels. still not managed to trigger the camera
thank you i managed to get sort camera calibration
