How to send a string from a PC to RaspberryPI with telemetry over Pixhawk
Hi everyone,
I want to send a string from my PC to my companion computer (raspberry PI) over Pixhawk.
You can see the structure that I want to create below
PC → Telemetry → Pixhawk → Telemetry → RaspberryPI
For this purpose, I’m using the code below for listening the outputs from the telemetry.
import sys
import time
from pymavlink import mavutil
# Connect to the serial port
master = mavutil.mavlink_connection('/dev/serial0', baud=57600)
# Wait for the heartbeat message
master.wait_heartbeat()
while True:
    # Get a MAVLink message
    msg = master.recv_msg()
    # Print the message if it is not a null message
    if msg is not None:
        print(msg)
    # Sleep for a short amount of time
    time.sleep(0.01)
But I couldn’t find a way to send the string. I couldn’t find something about it in the web except this page. But there is not much information to do the actual operation.
Can you help me out please, how can I send a string?
I sent my string from laptop with the code below:
import time
# Connect to Pixhawk over serial port
master = mavutil.mavlink_connection('COM9', baud=57600)
# Wait for the heartbeat message to confirm the connection
# Send a status text message with severity info
text = "Hello Pixhawk".encode('utf-8')
master.mav.statustext_send(mavutil.mavlink.MAV_SEVERITY_INFO, text)
# Wait a bit to give Pixhawk time to process the message
time.sleep(1)
Then, I catch this command from my Raspberry PI with the code below. You can change the if statement with the “commandGCS:”. I add it for identifying my strings from other mavlink messages. I will add “commandGCS:” to every string I sent.
import time
# Receive messages from Pixhawk
while True:
    if msg and msg.get_type() == "STATUSTEXT":
        text = msg.text
        if text.startswith("commandGCS:"):
            # Process the message
            print("Received command:", text)
            # You can add your own logic here to handle the received message
Hope it could help to future people. Don’t forget to change the connection addresses and baudrates according to your configuration.
