Hi there ,
I am try to read esc data in Hobbywing X ROTOR X8 100 Kv. I am trying read esc data usb ttl but ı dont read actually data is coming but ı dont show serial port terminal. Can ı do without hobbywing datalink ? I couldn’t find any documentation on connecting to the ESC other than datalink. With which communication protocol does hobbywing XROTOR X8 ESCs send data?
Can you help me please ?
ArduPilot:master
← peterbarker:pr/hwing-platinum-v3
opened 01:56AM - 13 Jan 23 UTC
This PR now parses both v3 and v4 protocols.
edit: added support for the XRoto… r-v4
edit: added support for DataLink devices
Something like this: https://www.dragonrc.com.au/HW-100A-V3-Platinum-series-aircraft-system-p/drc-hw100av3.htm
Reads telemetry data from this ESC and makes it available via ESC telemetry.
Includes simulator for same.
There are some things that we need to discuss:
- tridge is uneasy with the new parameters, worried we're going to end up with way too many of them
- he's thinking in the main firmware we have a single parameter, an enumeration of which (single) protocol you want to parse
- so something like `AP_ESC_Telemetry::Protocol::HobbyWingPlatinumProv3`, `AP_ESC_Telemetry::Protocol::TMotor` etc
- tridge suggested this go onto the IO thread
- I'm uneasy with that, having looked at what else is on that thread. Given this has to be relatively-real-time, I'm not sure it should share a thread with SD card formatting, parameter-saving and SmartRTL cleanup.
- perhaps we could have a thread dedicated to telemetry in general (and maybe move blheli to it?)
- is the use of the serial timing-constraint code legit?
Board AP_Periph blimp copter heli plane rover sub
Durandal 1304 1408 1408 1224 1416 1280
Hitec-Airspeed 0
KakuteH7-bdshot 1216 1264 1272 1240 1248 1216
MatekF405 0 0 0 0 0 0
Pixhawk1-1M 0 0 0 0 0 0
f103-QiotekPeriph 0
f303-Universal 0
revo-mini 0 0 0 0 0 0
skyviper-v2450 0
But you will need to compile the source code.
Thanks for answer I couldn’t find anything to solve my problem on the page you sent. My motor data cable colour are black , red and white but this video green and yellow .
Actually, I am trying to do the same thing as in this video, but when I connect to the drone can gui, I cannot access the data. I am sharing with you what I see on my screen. I would be happy if you help.
Did you recompile the source code after applying the changes from that or branch?
Did you upload the resulting firmware to your flight controller?
Yes I applied this. My problem is ı cant see org.dronecan.gui_tool in the dronecan gui. İf ı read this probably ı solve problem.
The T-Motor datalink V2 does not speak CAN properly. You need to connect serially to it.
Have you read the GitHub PR text? It explains how to configure it.
16 01 02 33 39 00 87 00 87 04 0F 01 CC 00 03 00 23 D2 D2 00 00 D8 04
9B 16 01 02 33 3A 00 87 00 87 04 0F 01 CC 00 03 00 24 D2 D2 00 00 DA 04
9B 16 01 02 33 3B 00 87 00 87 04 10 01 CB 00 03 00 23 D2 D2 00 00 DA 04
9B 16 01 02 33 3C 00 87 00 87 04 10 01 CC 00 03 00 23 D2 D2 00 00 DC 04
9B 16 01 02 33 3D 00 87 00 87 04 10 01 CB 00 03 00 23 D2 D2 00 00 DC 04
9B 16 01 02 33 3E 00 87 00 87 04 11 01 CC 00 03 00 23 D2 D2 00 00 DF 04
9B 16 01 02 33 3F 00 87 00 87 04 11 01 CC 00 03 00 26 D2 D2 00 00 E3 04
9B 16 01 02 33 40 00 87 00 87 04 0F 01 CC 00 03 00 25 D2 D2 00 00 E1 04
9B 16 01 02 33 41 00 87 00 87 04 10 01 CC 00 03 00 25 D2 D2 00 00 E3 04
9B 16 01 02 33 42 00 87 00 87 04 11 01 CC 00 03 00 24 D2 D2 00 00 E4 04
9B 16 01 02 33 43 00 86 00 86 04 11 01 CC 00 03 00 22 D2 D2 00 00 E1 04
9B 16 01 02 33 44 00 87 00 87 04 10 01 CC 00 03 00 24 D2 D2 00 00 E5 04
There are my raw data and protocol file. Current data is wrong can you check this?
