Hello, I wanna know how to power the apm with batterie without power module, please help
Look for a converter 2S/3S/4S, etc, to +5V (electronically not very different to a PM, though).
Thank you for your reply,
I have never use ardu pilot, when i connect the battery, nothing happened i don’t have power module also,
I don’t know where to find converter
Any other solution ?
Connect battery without module
A PM will simplify your life, giving you voltage and current measurements.
If for any reason you don’t want to use a PM, and don’t know where to find a converter, look for a BEC (battery eliminator circuit) at hobby shops, Aliexpress, Amazon…
Replay: PM’s, voltage converters and BEC’s are not electronically different (switching voltage converters).
After finding a BEC, how to install it to the apm board?
I find a lipo battery voltage tester in the box,
Is it interesting?
Do you have a complete video tuto?
I think it’s gonna help me a lot like I’m a beginner
How to use the JP1 pls in order to power the apm board
Here is some archived information for that obsolete and unsupported flight controller:
Old and Tired FC
Thank You for your reply, i found the solution, i use a jumper on JP1, now the apm board works well,
I did the program , accel calibration and compass
But the drone can’t take off
All motors are running but can’t take off the drone,
Pls
Where is THR_MAX param?
I don’t find it in my Mission Planner?
Pls
In the Full Parameter List.
dkemxr Dave
June 7In the Full Parameter List.
Visit Topic or reply to this email to respond.
To unsubscribe from these emails, click here.
Thx you for you reply,
I don’t have full param list
I have mission planer 1.3.76
Should I change a version of mission planer?
No. Go to Config>Planner>layout and select advanced and restart Mission Planner.
dkemxr Dave
June 7No. Go to Config>Planner>layout and select advanced and restart Mission Planner.
Thx you, i find these params
Are they okay ?
I don’t know. That version of firmware for the APM Flight Controller hasn’t been current in 7 years. You won’t find many around who remember much about it as the parameters have vastly changed since then. That’s why is listed as Unsupported…
dkemxr Dave
June 7I don’t know. That version of firmware for the APM Flight Controller hasn’t been current in 7 years. You won’t find many around who remember much about it as the parameters have vastly changed since then. That’s why is listed as Unsupported…
so should i use the latest version of mission planer?
I don’t know what to do
Describe the components on the craft and it’s weight with the battery:
Motors (size and kV)
Prop size
Battery power (3S, 4S, 6S)
Are the Motors in the right order and turning in the right direction?
