I like to suggest adding the followings to line 60 and 61. Most compare software are sensitive to floating numbers ending with .0 (1.0, 2.0, 3.0) and MP parameter saving for floating number with ending 0, becomes integer number (5.0 → 5).
if int(default_value) == default_value and isinstance(default_value, float):
default_value = int(default_value)
for param_name, default_value in defaults.items():
print(f"{param_name},{default_value}")
Hello @Jai.GAY you are probably not using the latest version included in the diatone_taycan_mxc.zip file.
That version already includes the changes you propose.
Thanks for the heads up, I will remove the older version now.
Hello @amilcarlucas , awsome work!
One more question, maybe regarding larger drones: Is Magfit and Large Vehicle MagCal enough? How about compass mot? I have seen improvements with compass_mot, and also large changes at the reading of the compasses when the ampers get high
I am also reminding you that you wanted to post the S900 tune!
Thanks!
In-flight mag fit is, if done properly, a superset of all others.
But on vehicles with high currents flowing close to the compass, it is better to do a compass mot, before the inflight magfit.
After Magfit calibration (or maybe arducopter compass calibration) the drone can be deployed in different regions , do you just use COMPASS_LEARN 1 or do you redo the magfit? I never understood why to use magfit if location of UAV can be 100km apart .
Do not change COMPASS_LEARN=0 and do not redo magfit. It just works fine, it uses GPS to get the local magnetic declination. No need for anything else.
One more question I have is, if the users run a second autotune immediately or 30 minutes later after the first successful autotune, what will the users expect from the second autotune? I mean about the tuned values. Are they going to be close? I did try before but a few weeks apart, their values are not close. I am just curious.
Are you asking about the second roll-pitch autotune?
The tuned values will be close to the first roll pitch values, yes.
The resulting values are in the files, why are you asking this?
It makes no difference 30 minutes or 30 days as long as the wind conditions are the same.
After Autotune, I like to know if there is a graph or methodology to confirm a good calibration or better control flying machine especially loiter flight mode. How do the experienced UA pilots confirm it? How each loiter parameter affect the flying and control.
Thanks for this it looks really great. I will try following.
I think this is important. Ardupilot carries the natural caveats of being multipurpose/multitargeted.
It’s so easy to miss a important parameter, or step, or detail.
I experienced this after I started my second setup configuration. My conclusion was I need a cheklist for this. It sure needs to be methodological.
Section 8 mentioned it is for Alt-hold flight mode. Does it apply to Loiter flight mode?
what is a good transient response value? less than 60ms. 0msec is the best. Is my understanding correct?
If the transient response is above 60ms, how do users tune the Loiter parameters to bring the transient response nearer to 0sec?
So yes, Section8 does apply to Loiter and Auto and all other modes. The inner loops need to be tuned (fast-transient response, good noise rejection, low overshoot, stable, etc) for the outer loop to even have a chance of getting tuned and do its work.
A good transient response depends on the size of your vehicle. A 300g vehicle will potentially be more agile than a 300Kg one. There is no one value fits all. But yes, the smaller the better.
To improve the loiter response, you first need to make sure the innermost angle rate control loop is performing correctly, after that the second level angle control loop is doing OK. And only after that you tune the outermost position control loop.
