Analytical Multicopter Flight Controller PID Optimization
After a mathematical model for the Multicopter is determined using System ID Mode, the PID flight controller parameters are optimized using a multi-objective optimization.
Since the model is linear, a control optimization tool for linear system analysis in MATLAB is applied.
To make the controller parameters adjustable by the optimization algorithm, the PID flight controllers for the stabilize flight mode have been modeled in MATLAB.
The following sections regarding the optimization goals and results are only valid for the examined quadcopter with a weight of 1.5 kg, an arm length of 22 cm and 9 inch propellers.
The resulting parameters are specifically applicable for this copter configuration and must not be used for any other copter.
Optimization Goals
The following table shows the goals/requirements of the controller optimization.
The dynamics of the roll and pitch axes are very similar. Therefore, identical goals are applied to both axes.
The yaw axis behaves quite differently. It is assumed that disturbances due to translational motion and wind mainly influence the pitch and roll axes, hence the disturbance rejection is not optimized for the yaw axis.
Requirement Goal Pitch & Roll Yaw Optimization Target
Phase Margin 50° 50° Larger is better
Gain Margin 7 dB 7 dB Larger is better
Step Response: Response Time 0.02 s 0.2s Smaller is better
Step Response: Overshoot 5 % 5 % Smaller is better
Step Response: Stationary Error 5 % 0.1 % Smaller is better
Control Variable Max. Overshoot 80 % 10 % Smaller is better
Disturbance Rejection see graph below not applied Smaller is better
The frequency-based disturbance rejection curve in decibel is shown below.
As a reference, the blue line represents the rejection gain that is achieved with the default parameters of ArduCopter.
The optimized system is required to stay bellow the yellow area to have a better disturbance rejection.
Optimization Results in the Simulation
The next four plots show the bode plot of the closed-loop system, the simulation results for the tracking behavior of a 10 degree step, the normalized controller output corresponding to the angle step, and the disturbance behavior for the roll axis.
The normalized controller output evaluates whether the optimized behavior can actually be realized by the real system.
It is assumed that the disturbances act as external torques on the airframe.
Therefore, the disturbance behavior is simulated as a step added to the controller output signal.
Bode plot of the roll axis closed-loop system:
Roll axis Tracking Behaviour:
Roll axis Controller Output:
Roll axis Disturbance Behaviour:
In general, all figures show that the optimized parameters and the parameters obtained from autotune lead to a much better controller performance.
The Roll axis Tracking Behaviour Figure shows that the tracking behavior of the optimized parameterization is the fastest and does produce less overshoot than the other two controller parameter variants.
This is achieved by a sharp rise in the control variable, as depicted in the Roll axis Controller Output Figure.
Though, compared to autotune, the control output does not oscillate as much and decreases faster.
This behavior is easier to get executed by the motors, hence more desirable than the one from the autotuned parameters.
Heavier oscillations in the controller outputs lead to higher ESC temperatures and higher risk of ESC de-sync issues.
Disturbances lead to a larger system response for the optimized parameterization compared to autotune, as can be seen in the Roll axis Disturbance Behaviour Figure.
Though, the disturbance rejection happens much faster.
After two seconds, the vehicle has returned to the hover state.
The next plots show the results for the yaw axis.
Only the bode plot and the input tracking behavior is shown as the disturbance rejection was not optimized.
Bode plot of the yaw axis closed-loop system:
Yaw axis Tracking Behaviour:
Yaw axis Control Variables:
The Yaw axis Tracking Behaviour Figure is clearly improved by the optimization.
It is faster than the controller parameterized by autotune and does not produce any overshoot.
Again, as the Yaw axis Control Variables Figure illustrates, this is caused by a larger controller output.
Though, its value stays in a acceptable range and is realizable in real flight.
For performance evaluation, the following metrics from classic control theory are used:
Criteria Description Qualitative Target
Bandwidth First frequency where the amplitude gain drops below -3 dB Larger is better
Gain Margin Amplitude gain reserve that can still be applied at a phase shift of -180° without the system losing stability. Needs to be positive for the system to be stable. Larger is better
Phase Margin Phase shift reserve at an amplitude gain of 0 dB.Needs to be positive for the system to be stable. Larger is better
Phase Crossing Frequency Frequency at which the phase shift curve crosses -180° Neutral
Gain Crossing Frequency Frequency at which the amplitude gain crosses 0 dB. A larger crossing frequency means that closed control loop has a larger cutoff frequency as well. As a consequence, the closed-loop has a quicker reaction to changes of the desired value or of disturbances Larger is better
Tracking Rise Time Time that the system response needs to go from 10% to 90% of the final step value. Smaller is better
Tracking Overshoot Exceedance of the final step value expressed in percentage of the desired step height. Smaller is better
Tracking Settling Time Point of time after which the system response stays in 2% error band around the final step value. Smaller is better
Disturbance Rejection Overshoot Exceedance of zero (= no system response to disturbance) expressed in percentage of the disturbance step height. Smaller is better
Disturbance Rejection Settling Time Point of time after which the system response stays in 2% error band around stationary state (= 0). Smaller is better
The following table shows these metrics for all three controller parameter variations for the roll axis.
Bold numbers show the best result of the respective category.
It shows that the default parameterization has the highest gain and phase margin due to its slow controller.
All other criteria of the default parameters confirm the bad performance seen in the plots above.
The last four metrics could not be computed since the controller is not able to reach the final step value for the tracking or to make the vehicle return to steady state in case of an disturbance respectively.
The optimized controller still has very high gain and phase margins compared to the autotune controller.
It also produces a low tracking overshoot and is able to reach the 2% error band of the desired step value very quick.
The autotune controller shows a slightly faster rising time which also corresponds to the higher bandwidth and gain crossover frequency of the controller with the autotune settings.
The metrics for the disturbance rejection also reflect the plotted results above.
While the disturbance rejection overshoot of the autotune is lower by a fair bit, the optimized controller only needs about halve the time to compensate the disturbance.
Criteria Default Optimized Autotune Qualitative Target
Bandwidth (Hz) 0.92 5.14 8.66 Larger is better
Gain Margin (dB) at f_pc 13.96 8.65 1.85 Larger is better
Phase Margin (deg) at f_gc 79.36 56.75 50.19 Larger is better
Phase crossover frequency f_pc (Hz) 5.01 5.94 6.35 neutral
Gain crossover frequency f_gc (Hz) 0.75 2.3 2.52 Larger is better
Tracking Rise Time (s) 8.35 0.068 0.047 Smaller is better
Tracking Overshoot (%) 0.00 6.57 29.49 Smaller is better
Tracking Settling Time (s) n.a. 1.81 7.67 Smaller is better
Disturbance Rejection Overshoot (%) 110.04 46.61 29.92 Smaller is better
Disturbance Rejection Settling Time (s) n.a. 1.39 3.46 Smaller is better
The next table contains the metrics for the yaw axis.
Again, the default controller shows the highest gain margin followed by the optimized parameterization and the autotune controller with the lowest margins.
Contrary to the roll axis, the optimized controller has the highest phase margin and the highest bandwidth as well.
Regarding the tracking behavior, the autotune controller has a slightly shorter rise time.
The optimized parameterization has no tracking overshoot at all and needs less time to reach the 2% error band of the final step value, as it was already the case for the roll axis.
Bandwidth (Hz) 0.73 1.84 1.58 Larger is better
Gain Margin (dB) at f_pc 25.92 11.44 2.35 Larger is better
Phase Margin (deg) at f_gc 13.27 60.63 7.97 Larger is better
Phase crossover frequency f_pc (Hz) 3.01 5.9 3.01 neutral
Gain crossover frequency f_gc (Hz) 0.55 1.84 1.76 Larger is better
Tracking Rise Time (s) 0.47 0.214 0.21 Smaller is better
Tracking Overshoot (%) 17.16 0.00 3.96 Smaller is better
Tracking Settling Time (s) 3.25 1.42 1.65 Smaller is better
The following two tables show the optimized flight controller parameters for the roll and yaw axis compared to the default parameters of ArduCopter.
The defaults are also used as initial parameters for the optimization.
As a reference, parameters obtained from an autotune flight with AUTOTUNE_AGGR = 0.1 are also shown.
It shows that the optimized parameters differ greatly from the default and autotune parameters.
Again remember that the presented results are only valid for the examined quadcopter with a weight of 1.5 kg, an arm length of 22 cm and 9 inch propellers.
Roll:
Parameter Default Optimized Autotune
ATC_RAT_RLL_P 0.1350 0.123 0.240025
ATC_RAT_RLL_I 0.1350 1.0 0.240025
ATC_RAT_RLL_D 0.0036 0.0053 0.007948
ATC_RAT_RLL_FF 0 0 0
ATC_RAT_RLL_FLTT 23.0000 50.256 5.0
ATC_RAT_RLL_FLTD 23.0000 55.557 23.0
ATC_RAT_RLL_FLTE 0 0 0
ATC_ANG_RLL_P 4.5 11.6480 16.670347
Yaw:
ATC_RAT_YAW_P 0.18 0.0013 0.894938
ATC_RAT_YAW_I 0.018 0 0.089494
ATC_RAT_YAW_D 0 0.041 0
ATC_RAT_YAW_FF 0 0.0183 0
ATC_RAT_YAW_FLTT 23.0000 0 23.0
ATC_RAT_YAW_FLTD 0 2.25 23.0
ATC_RAT_YAW_FLTE 0 0 3
ATC_ANG_YAW_P 4.5 19.6323 7.599
Conclusion
An optimal analytical PID solution constraint to a predefined set of requirements is found using the method presented above.
We got these results tuning our copter at IAV GmbH and created the automation to preform these steps on any other multicopter vehicle.
Contact us if you are interested in optimizing your vehicle.
Enjoy,
Fabian Bredemeier
Amilcar do Carmo Lucas
Link not working right now please review Edit: now working, . Please show us your build as well.
The test subject was a full 3D printed vehicle:
Very cool.-----------
This is super cool. I’ve seen this used in the aerospace industry, but I’ve never learned. I have been wanting to learn this and apply it to Ardupilot. When I get some time, I definitely want to give this a go. Great work!
Just a thought: Could tensile modulus and overall rigidity of the 3D printed frame also play a big part in the PID optimization? It would be interesting to see the same design printed in different materials like PA6-CF vs PA12CF for HTN-25 CF, with various print orientations, infills, etc.
Yes, of course it does.
Rigidity is our friend.
The purpose of this vehicle is rapid software prototyping and testing, we have four of these copters, and the design is good enough for that. And yes, it can certainly be improved upon
We just tested a 3D printed 6S quad with 18" props today and it handled surprisingly well. I’ll check out the logs later but for a first flight, I’m feeling pretty good. Vibration was minimal, probably because it’s rigid enough to have good feedback but flexible enough to dampen vibrations. Might have found a goldilocks design here…
@amilcarlucas Thank you so much for the post. It is really interesting!
Have you test flown the optimized parameters? I find it interesting that the ATC_ANG_*_P parameters are larger than the recommended maximum values. Especially on the yaw axis where the other gains are so low. It would be interesting to see the flight step response plots for before and after the optimization.
Hello @Mitch , welcome to the community,
yes, we have flown the optimized parameters, and feel they are better.
We have step response plots comparisons between default PIDs, autotune PIDs and optimized PIDs.
For most users autotune is good enough. For professional users, knowing what they want and willing to do the effort to get it, optimized PIDs are better.
This can and should be combined with ArduCopter’s simulink model to get proper results, and should be done after Methodically configure and tune ArduCopter
I just found the simulink model of the Arducopter control system and explored it in simulink. Is there any documentation available that gives clear detailed steps on how to integrate the obtained transfer functions after doing System Identification flights with the simulink model?
No, but IAV does provide consultancy services on PID optimization
