Another methodic review, this user was more methodic and accurate:
I’ve been using your Annotation script and it’s working really well. Do you have (or know of) a script that will pull all the non-default parameters from a full parameter file? I know MP has an option to show non-default parameters but it won’t extract just those to a file.
Currently, I extract the default by amilcarlucas from a bin file and use a software to compare it, I see the changes make to the default values.
I have scripts that do that, but they are not open source.
@amilcarlucas Hey i saw there is something like.
Z vibrations are caused by the downwash of each blade hitting the arm and the forward traveling propeller hitting the oncoming air when moving.
how i could fix that?
Stiffen the frame, use stiffer props.
I open sourced it in the form of a PR for ArduPilot extract_default_params.py.
Enjoy
I installed bluejay then went to install the bd firmware and discovered there isnt a bdshot fimware for hte speedybeef405mini or the JHEMCU-GSF405A that I have. Is there a reason those boards dont support it?
They both support bidirectional DShot. It’s the opposite - there is no firmware version for them, which does not support BDShot.
what should SERVO_DSHOT_ESC be set for to use bluejay escs on blheli-s?
I don’t really know whether the answer is right, but it seems from experience that Bluejay understands options 2 and 4 for SERVO_DSHOT_ESC (that is, both related to blheli_s).
At least they work well in flight, and option 4 enables extended telemetry. There is not really much coming via extended telemetry in the case of typical hardware running Bluejay, but I am working on supporting Extended DShot Telemetry v2 in Ardupilot, which will bring some status information about how much an ESC struggles to keep it going.
The RPM is coming through now thank you.
The process can be automated with the new ArduPilot Methodic Configurator available from ArduPilot Methodic Configurator github repository
2 or 4. The reason the settings are different is because BLHeli_S/BlueJay use MCUs that are not able to leverage some of the newer features of 32-bit MCUs (e.g. DMA) and thus are quite timing sensitive (they use bit-banging instead). The settings change the calculation of the high/low period for dshot in a way that these firmware’s seem happier with. Why don’t they follow the standard you might reasonably ask? Well first off there isn’t really a “standard” for dshot timing. The output bitrates are fixed, but the duty cycle within that is not. Second off, blame BetaFlight - my suspicion is that many ESC manufacturers only test against BetaFlight in development - so if it works in BetaFlight they assume “job done” and move on. But BetaFlight itself also has some variability in timing because it also uses bit-banging in many instances. So what this boils down to is us trying to replicate BetaFlight timings on a very different platform, without a standard - and surprise, surprise, not everything works as expected.
FETtec is a better protocol in that regard. the checksum is not the best, but at least the timing is a lot simpler.
The GUI tool can now replace the text editor even when no flight controller is connected to it.
Did a temperature calibration step by step , but had different results
Reason for redoing was because the first time I left the FC in freezer only for few mins was a bit hesitant. And second calibration I thought my dog had entered the room and must have pushed the table where the FC was kept.
Total did 3 calibrations and all had different results. I understand tmin can be different depending on how long we keep the FC in freezer but tmax behaved quiet different in all 3 calibrations and all results are quiet different. Could you have a look.
Also the drone might have to operate in temp ranging from -10C to 55c .
Pixhawk orange cube+
Attempt 1- temp cal1 - Google Drive
Attempt 2 temp cal 2 - Google Drive
Attempt 3 temp cal 3 - Google Drive
The second one looks the best. Use that one.
I have a drone with pixhawk cube orange FC in which temp calibration wasn’t done previously. The drone is tuned and have been flying it for a time now. Is it possible to do just the temp cal now? Will it hamper my pids? Or tuning ?
