How to make new flightmodes visible in Mission Planner?
Hey,
I’ve implemented a new flightmode and now currently trying to use the flightmode.
So I edited the firmware, compiled it and got a .apj file.
I’ve uploaded it on Open Pilot Revolution and connected it to Mission Planner.
I’ve thought I could choose the flightmode under “config” -> “flightmode”.
My flightmode did not appear in the drop down list. ;(
Are there good examples on how to successfully implement and use a selfmade flightmode?
Currently stuck. :confused:
Hope you can help me out. :slight_smile:
Best regards
DezzardHD
Did you follow this wiki page:
https://ardupilot.org/dev/docs/apmcopter-adding-a-new-flight-mode.html#adding-a-new-flight-mode-to-copter
Take close look at step 6 and 7 (assuming you did all of the first 5 steps correctly).
Did you able to change the flight mode using transmitter?
Check this link. I was able to add a new flight mode name to Mission Planner by only editing the ParameterMetaData.xml file.
Thanks! That helped me!
Does this method still work? there is no file named ParameterMetaData.xml instead there is a file named ParameterMetaDataBackup.xml. I modified it but didn’t work.
Did you ever figure out how the issue Sena? I am running into the same problem now
