How to interpret ESC-Err in the logs?
I noticed that I got ESC-Err up to 40 when changing the throttle rapidly. What does that mean and how serious is it? How do I debug it?
I’m attaching a log at the bench without props.
ESC Err.zip (355.6 KB)
Pretty sure it’s the percentage of bad telemetry packets. Regular serial ESC telemetry doesn’t have a dedicated error bit like EDTv2 does.
As for how serious it is, I would keep it in the back of the head, but if it goes away once props are attached I wouldn’t worry. Without props you’re basically running ESCs and motors off-spec.
I tried with props but the error rates look the same. My guess is that it is the signal cable running in parallell with the power cables to the ESCs.
But if it’s just the telemetry the plane won’t crash if it misses some RPM readings. Throttle response is good enough. Since it is a plane a couple of milli-seconds of delay doesn’t really matter (if the error rate is the same for the signal in the other direction). The airframe is cheap and light (foam board) so I’ll try flying it tomorrow unless anyone sees any other risks.
with props.zip (499.6 KB)
If your ESCs and FC support it you can try flashing a BDShot firmware and configure EDTv2 telemetry. That way you get info about actual ESC errors, e.g. desync, demag events.
But yeah, I’d just send it too. No need to obsess over something that likely isn’t an issue.
I’ve updated the ESC firmware and did a quick test without props but did not get the extended telemetry (from the pull request I understand it as it would have the name EDT2?).
Do I need to enable any additional setting in the configuration? I’m running Arduplane 4.5.4, MatekF405-Wing-bdshot.
I’ve long since I admitted that I like looking at logs and telemetry even though I just get more ancious by doing so :slight_smile: . The weather forecast still looks good for tomorrow so I’ll fly then.
Yep, should be under EDT2 in the logs.
SERVO_DSHOT_ESC,3, but not all ESCs support it, you’ll have to try and find out. Also, BLHeli32 needs to be version 32.7+. If it isn’t you’re out of luck because of a certain closed source software company…
I set SERVO_DSHOT_ESC=3 this morning. I had multiple sucessfull flights. I did not get any EDT2 logs. I’m using Bluejay 0.21 on two EMAX D-Shot Bullet series ESCs and as previously mentioned the FC is running Arduplane 4.5.4 with the MatekF405-Wing-bdshot firmware. Is there anything else I can do to determine why I don’t get the EDT2-logs?
On the last flight the auto-take-off decided to level out at 2-3 meters and turn into a hawthorn bush at full throttle. Looking at the logs the RPM, current and airspeed was the same as on other flights. So it wasn’t a ESC issue. I will start another thread trying to determine the root cause of that accident since it is unrelated.
Sorry pal, I just assumed you were using BLHeli32. For Bluejay SERVO_DSHOT_ESC,4 might work.
It used to have a value of 1 and work so I assumed that 3 would be correct. If I had 2 previously, I would have tried 4. That hardest part is finding the right parameter to change. I guess it worked with 1 since I didn’t use any commands that were different between BLHeli_S and 32.
Once I got the plane patched up, I will try the with 4 instead.
Here’s the thread where I describe the crash at take-off.
I flew again and ran autotune a couple of times. While doing that I had SERVO_DSHOT_ESC,4. Still no EDT2 in the logs.
Power felt completely fine so I do not think I’ll pursue this more. I get RPM and the filtering works perfectly. That’s the important part and what I could expect from the cheapest ESC I could find that supported BDSHOT. Thanks for the help!
The EDTv2 support is I believe not yet available in the 4.5 branch. It’s merged into master and should likely appear in 4.6.
It’s most useful with Bluejay, but AM32 has plans to support it too (source: Discord messages).
Thanks, I’ll check again once there is a RC of 4.6 then.
It was working as of 4.5-DEV so it should work in current Stable.
I don’t see this in the Copter-4.5 branch, in particular, here:
which should be roughly like this for EDTv2 to work:
The basic EDT with RPMs and error percentages has of course been available for quite a while.
I’m getting it on V4.5.4 with a BLHeli_32 ESC V32.10. RPM, Voltage and Temperature.
That’s EDT but not EDTv2. The latter offers bits about desyncs, demag and stall events, as well as commutation stress. BlHeli32 does not report that, although it sends some frames when not armed that get parsed by this logic.
Yes, you are right. I missed the v2 part.
