Pls advice how can I plan a mission with specified ground speed of an airplane in a certain waypoint?
Tried to simulate DO_CHANGE_SPEED command, but a plane doesn’t change the speed.
Any thoughts?
Any thoughts?
There is a minimum ground speed parameter, though it may be exclusive to copter firmware.
If you set It to your desired speed and set commanded air speed low enough your plane should try to maintain ground speed. I wouldn’t expect much precision from that though.
Alternatively you can use Lua to either actively modify desired airspeed or take over throttle control from TECS and run your own throttle controller. This however comes with few caveats
Scripting requires H7 based flight controller.
