Hello All,
I’m using Mission Planner. I need to know what setting or parameter do I use to change the altitude that my drone automatically climbs to when I take off manually. Thank you.
Hello All,
Only with an Auto Mode Takeoff command will it climb to a set altitude. When you say “take off manually” what do you mean?
I have seen a parameter for gps flight modes that can set a takeoff altitude. I believe its pilot_takeoff in the full parameter tree?
I don’t think this has a use from Mission Planner. However it should work in QGroundControl as a Guided Mode takeoff. Never tried it.
Sorry, but that’s not correct.
There are two sorts of automatic takeoff in ArduPilot; one sort used by
Guided and Auto, and another that’s usable in altitude-controlled modes.
Solo actually uses the second sort; if you take off in loiter then the
vehicle bounces up to a pre-set height:
https://ardupilot.org/copter/docs/parameters.html#pilot-tkoff-alt-pilot-takeoff-altitude
Ah OK, thanks for the correction. Only Solo for the Altitude Controlled mode takeoff?
Nope, that was just an example. It’s available generally.
Yea, I see in the Simulator. Cool.
