How to connect bmp280 sensor to pixhawk2 with i2c
Hi~
I have some problem.
Attempts to connect the external temperature sensor (bmp280) to the pixhawk2 using i2c method fail.
how to apply the sensor. please help me.!
pixhawk2 / bmp280
V/Vin
SCL/SCK
SDA/SDI
GND/GND
I have connected the wiring as above.
FW ver : ArduCopter V3.6.7 (38b8af17)
Support for the BMP280 Barometer is in V3.7-dev.
http://ardupilot.org/copter/docs/common-baro-external.html
I see you have cross posted thisโ€ฆ
As far as the wiring is concerned, from the Adafruit page:
" I2C Logic pins:
  • SCK - this is also the I2C clock pin, connect to your microcontrollers I2C clock line.
  • SDI - this is also the I2C data pin, connect to your microcontrollers I2C data line.
Leave the other pins disconnected"
