Hi guys, needing your help on this please. I recently downloaded Mission Maker for Ardupilot but when I click Arm, then slide button it wont arm. It will only arm using Radio Transmitter when I hold the throttle on the lower left corner.
Is there a way that I can arm this using Mission Maker app only? If so, do I need to configure anything? Please help. Thanks.
Hi Sir @ekliptiko thank you for your response, but sorry im you mean by TX is the Radio Transmitter TX? Yes it it connected, the radio receiver is connected, Im just trying to arm the drone with mission maker then control it with the radio Transmitter.
You’re saying that it wont arm using the app because the rado transmitter is currently enable? that in order for me to arm using the amm i need to disconnect the radio receiver? Thank you.
