Just today I learned about the telemetry screen for taranis, and when researching about them, I found about the one from crafts and theory llc. Unfortunately, they are unavailable, so is there still a way to get the flightdeck, like another distributor or company?
How to acquire FlightDeck Telemetry
You don’t need a Teensy. Ardupilot natively supports Frsky telemetry. Everything you need to know is in the Link above.
but here in https://ardupilot.org/copter/docs/common-frsky-telemetry.html says it needs something to convert the signals and in here https://ardupilot.org/copter/docs/common-connecting-sport-fport.html#common-connecting-sport-fport says I would need a F7 or H7, that i don’t have, so I got a little confused. (I know there is a note saying that it’s no longer required, but since there was no warning saying it was archived or something, so I thought it is still needed for older models, like cube black @dkemxr
That’s just a simple inverter if you don’t have an F/H 7. You can build your own for a few $ or buy one. Here is one example:
https://www.amazon.com/Telemetry-Converter-Pixhawk-Taranis-Receiver/dp/B07KJFWTCB/ref=sr_1_4?crid=V700F0Q7HNY&dchild=1&keywords=frsky+yaapu+telemetry+converter+cable+pixhawk&qid=1614978679&sprefix=frsky+telemetry+cable%2Caps%2C213&sr=8-4
could I do that with the teensy 2.0? I ask that because I already bought the teensy
sorry if I am asking too much @dkemxr , I am a newbie that still figuring out the ropes of drone world, thank you for your help.
I keep repeating questions about the teensy because I am part of project that is developing a drone, and it was out of my recommendation that the teensy 2.0 was bought and I am trying to see if it can be used as the inverter/converter you said , otherwise we bought a component for nothing.
I don’t see the sense in using a microcontroller for such a simple task.
