How the Drone Tag DRI module prevents tampering?
My remote id module is Drone Tag DRI, not open-source openDroneid. How to set the parameter values of the DID_OPTIONS, and then you can change the values of the UAS ID, UAS ID Type, UA Type to modify the initial values of the factory settings, and keep these values after modification to prevent others from tampering. Prevent tampering with the settings of unmanned aircraft systems (UAS), especially when it comes to identification (ID) information.Is it possible to set the parameters of the DID_TYPE to prevent others from tampering?
If you control the tamper-proof mode of the module through the Lock_level, you cannot add firmware to DronTag.
