LI-po 12S 2P , 16,000 mah 50v (4.20v / cell)
set the minimum voltage for fail safe to 42.0v
Li-ion semi-solid state 12S 2P , 16,000 mah 48.8 v (4.10v/cell)
So, what’s the appropriate minimum voltage for fail safe of Li-ion semi-solid state 12S 2P.
LiPo’s are a very well known quantity, and they’re all the same really.
LiIons are different from manufacturer to manufacturer so check the specs for the exact voltages - particularly the usable minimum voltage that the cell can recover from.
If in doubt use the generic LiIon values in the Initial Parameter calculator in MissionPlanner.
