The drone make beep beep sounds from motors after powered and not arm for a while, how to cancel that sounds
With Blheli/Blheli 32 Firmware tool you can remove it.
@Gino_Nencioni So the beep signal is not coming from flight controller? But I power the esc and motor alone ,it didn’t make beep beep sound
Changing parameter “Beacon Delay” in BLHeli configure tool will fix the need
I have the same question with the T-Motor F55A Pro-II ESC. Does anybody know how to adjust the “adjustable parameters” mentioned on their website?
It’s a BLHeli_32 ESC so connect using BLHeliSuite and turn off Beacon Delay. Just like it says in the post above yours.
Oh, is it? Didn’t know that. Thanks for the enlightenment!
(Edit: Well, now I see that the product page actually says so. That’s what happens when you don’t know what to look for …)
