Hi, how can I check if my ESCs are working? I try to check my motors but they doesn’t work… I hear a double beep (the first lower tone, the second upper) and nothing else…
No propeller mounted, some tools like this help.
Thx! Actually the motors (two T200 bluerobotics) beep twice when I connect the Pixhawk to the battery, but when I try to check the motors with QGC they don’t spin… What’s the problem in your opinion? Thx!
Which flight controller stack are you using? ArduPilot?
What did you do and expect it to spin?
I use Pixhawk, QGC, Rover firmware, 2 x T200 (and basic ESCs)…
When I try to check the motors with the QGC tools, they beep twice and nothing more (no spin at all)…
You mean PX4?
yes, inside a Pixhawk 2.4.8
When you are using PX4 you will probably have better luck getting a useable answer in the PX4 forum
