Instead of using mission planner with the power module, I have to use raspberry Pi for logging the voltage and current readings. Since Raspberry Pi has no analog pins, unlike arduino, for taking analog inputs on raspberry pi, I am using “Waveshare High Precision AD DA Board” and it is working perfectly fine. I am able to take analog readings using Pi and when I connect “holybro power module pm02” (voltage, current and ground) to the raspberry pi, I get the readings. For voltage readings, there is no problem but the current readings are fluctuating too much randomly.
Does the current pin on power module gives out analog voltage signals or analog current signals?
Anybody else tried reading pm02 v03 outputs directly through raspberry pi or arduino, without mission planner?
