I recently purchased the TD-650 frame kit. It comes with a 6x40A PDB, which has power ports on it for 12 and 5.3V. Do I need to use a power module in addition to this to power the flight controller (using a Cube Orange on the standard carrier board)? I have the default Power Brick Mini, but that is only rated for 30A continuous.
From the PDF you sent, it looks to me like you could use that board in place of the power brick that came with the Cube. The only thing I can’t see is if it has a current sensor on it.
I think the motor on the 650 might draw more current than the 450 though.
The PDB appears to have a pin marked batt_sense - not sure exactly what that means, but it looks like voltage, and current sense is NC. So I’d have to use a different module for current sensing.
I just discovered this as well (lack of current sense on the Hexsoon PDB) and chose to use a 4-in-1 ESC’s current output for that purpose. That won’t account for all of the peripherals (a VTX being the biggest non-sensed power hog), but it should capture the bulk of the current draw. I’d rather make that compromise than add yet another power brick to the build.
Otherwise, the PDB linked above seems to work perfectly fine for powering a Cube Orange, even with a fair number of peripherals connected.
