I have a Flamewheel F550 knockoff hexacopter which mostly works great with one exception…one motor is occasionally cutting out during flight, always the same motor HEXA-X #6. It only drops out for about a second, comes back and often drops out again 5 seconds to a minute later. I’ve changed both the ESC and motor and still seeing the same behavior. In this log the issue occurred about 1/2 dozen times. One instance is around 161105.
I’m not sure where to go from here. Anyone have any ideas on what I can look at next?
I don’t have another flight controller for this one. The FC is a Pixhawk. To test if issues is the output channel could I try unused output channel 7 or 8 instead by changing Position 6 from Motor6 to Motor 7/8?
