When raising the throttle by a little bit, not all motors turn on. All of them turn on at higher throttle but not at the same speed. I redid ESC calibrations for each ESC manually and each one turns on even a low throttle. When I tip the drone at angle, some of the motors that were not spinning start spinning even at low throttle. I have redone compass and accelerometer calibrations several times now and even switched to a new Pixhawk (still the same issue). What could be the issue(s)?
You should set MOT_SPIN_ARM to a value where all props start turning slowly when the drone is armed.
After that, set MOT_SPIN_MIN ~3% higher than MOT_SPIN_ARM.
Perhaps no issue. Use Mission Planners Motor Test to run the motors and properly set the motor ranges. What you are doing is irrelevant.
Setting Motor Ranges
That worked, thanks guys!
