Hero VTOL 4+1 Fixed wing
Thanks for the feedback on the problem, reducing the P or D value of the cross roll appropriately will reduce the vibration.
Will you upload more 3d files?
I want to see the fuselage before buying
Cannot decide between the hero and the striver
Sorry, we can only provide partial 3D files for easy modification and DIY.
https://github.com/makeflyeasy/MFE_ArduPlane
Hello @makeflyeasy,
We have selected your Hero PNP version for a development project.
What is the size of the box and the weight so that shipping costs €1078.07 to Spain?
I think it is a very high price when the cost of the Hero PNP version is €1,760.75.
Thank you.
@Luar The shipping cost is the price calculated by the trading platform, you can buy directly from our dealers with cheaper shipping costs.https://www.uavmodel.com
@makeflyeasy Do you have a list of things that are included in the PNP version of the Hero? Is it in stock?
@tegwin You click on the more information section of this link, which has a detailed list of configurations
https://www.aliexpress.us/item/3256804611396135.html?spm=a2g0o.store_pc_groupList.8148356.1.215812b54kcW3W&pdp_npi=4%40dis%21SGD%21SG%24%20989.03%21SG%24%20989.03%21%21%21711.38%21711.38%21%40213db7b317000186436834718ea18a%2112000030523953147%21sh%21SG%212531506054%21&gatewayAdapt=glo2usa4itemAdapt
Has anyone else experienced ESC failure on MFE ESCs?
I put together our first HERO VTOL kit and managed a 6 second hover before one of the VTOL ESCs spectacularly failed causing a crash and big damage to the fuselage and wing. Most disappointing.
ESCs had been tested on the bench and appeared to be functioning as normal so we signed them off for flight trials.
@tegwin Very sorry to hear from you, I got the same message at the dealer this morning.
I’m not sure at what point in production or assembly something went wrong.
You swap the ESC first to check for damage to the motor, or anything else that might be damaged, then contact the dealer and he will help you try to fix the problem.
Hello makeflyeasy,
Yesterday I bought your Hero, I hope to have it in three or four weeks.
My question is about the battery to install.
What do you recommend, a single 22000 mAh battery or two 11000 mAh batteries connected in parallel?
Have you tested with these two configurations?
Thank you.
RaĂșl
The battery I tested is a 6S 22000mah, the battery compartment has more space, as long as it meets the discharge capacity, it can be used.
Hello, I’m new to this group. I’m in the process of building the Hero VTOL using the CubePilot Ecosystem and was wondering which power distribution system or configuration was working the best. Thank you+
https://endoc.makeflyeasy.com/#/Hero/ENHEROVTOL
You can refer to the Hero VTOL assembly video link above.
Thank you for the information. I was really interested in what the “best” recommended power distribution system folks were using with their Cubepilot. I have the Orange+ with the standard carrier board that I was installing in the Hero.
Hello Mike,
Do you have a build list , or video on what your Ardupilot electronic material setup is like on the Hero? I have the Orange+ with the standard carrier board and plan on using the CubePilot Ecosystem on my build.
A few days ago we did the first hover test.
HDPILOT, we flew a cube orange + with Hauchi 200 A power module.
In this test the consumption is 40 A in Qstabilize and Qhover, it seems a lot to me, the battery is a 22000 mAh 6s tattu.
I have not weighed the plane.
Here is a short video of the hover flight.
VID-20240731-WA0001.mp4
Thanks.
Rau’l
Do you believe the ESC’s amperage are too low for these motors? or both the ESC’c and the motors are to under-powered to handle the load?
I have not explained myself well.
The 40 Amps are in this hover flight, therefore it is 10 Amps per motor.
The ESCs are well sized since they are 50 Amps.
The motor and ESC set are well sized since without making any configuration the plane remains perfectly hovered at half the throttle travel.
No
No.
For the moment until I do more tests I am happy with the results.
what is the actual weight of the Hero VTOL frame without any electronics / payload ?
The KIT version weighs 1.72KG.
