I have uploaded the following video on youtube in order for anyone that knows to help me out with what is the problem i am seeing. I have NOT flown and not willing to try anything till i figure it out.
Thanx in advance
Is this a radio failsafe? Seems the yellow is single yellow, but after with the button during boot works.
Any ideas?
Seems the system hangs on GPS detection. from what i see on MP Messages
GPS 1: detected as u-blox at 115200 baud
Initialising APM
Barometer calibration complete
Calibrating barometer
u-blox 1 HW: 00080000 SW: EXT CORE 3.01 (107900)
PreArm: Hardware safety switch
EKF2 IMU1 tilt alignment complete
EKF2 IMU0 tilt alignment complete
Initialising APM
Frame: OCTA_QUAD
fmuv3 00240033 30365109 31353833
ChibiOS: d2030d88
ArduCopter V3.6.5 (d37125bd)
UPDATE AFTER A MILLION TESTS: I decided to disable BRD_SAFETYENABLE and now it boots properly @proficnc any idea as what it might be?
After alot of testing i realized that if i completely disconnect my Telemetry from the board and connect it only after it boots, everything works fine, which makes it strange since this had never been an issue in the past with a similar module. In the morning i will connect the Tmodule direct on a BEC and make a series of tests. Might be that power on boot is not enough from the powerbrick with the Tmodule connected and hangs on boot.
As soon as everything is verified i will post my finding, that may help other people in the future. What i would like though is to find if there is a Here2 LED color code, which i was not able to find in any place.
Colour change will start to come with CAN code
I have seen similar effects from too many things on the power rail.
