I have the HERE GNSS GPS module connected to Pixhawk 2 and the GPS is not present in the Mission Planner.
The compass works fine and the arming button. The side led’s also do not work.
I flashed with APM:Copter 3.5.5 Quad
I cannot connect GPS module to PC because it has no usb connection.
All the stuff is brand new pirchased here: https://www.3dxr.co.uk/
Does anyone know what might be wrong? Could it be a hardware issue?
Im having exactly the same problem, haven’t tried on serial 4 so havent had any connection at all. But have tried a tersus receiver i have which worked straight away.
Can I bump this thread? I’m in a rush to get my pixhawk build done. It seems I have the same problem as OP. Has anyone found a solution to this beside a return? I don’t think the Pixhawk 2.1 comes with the cables to connect the Here GNSS to the GPS 2 port easily
I’m having the same issue as the original poster. I work in a lab where we have numerous Pixhawk 2’s around and this appears to be a hardware problem. After several hours of switching components and trying to debug, the only work around I can find is to send the pixhawk back to where you bought it from. For me, it appears to just be a Pixhawk 2 IO board problem. The cube and the GPS both seem to work just fine.
Had a very similar problem (GPS working poorly and recognized as a nmea 9600 instead of ublox at 115k), sent the Pixhawk 2.1 back and the replacment worked straight away with no issues. So i guess mine is an hardware prob on the carrier board.
