This thing claims to have Mavlink support and has a serial connection but there is no other information. Is this supported by Ardupilot?
just control by s.bus
I dont think that would allow things like POI?
Thanks, I saw that manual. I hope it will quickly get mavlink support like the other available gimbals.
This guy does a review and I think he mentions mavlink support is coming.
Itās a bit confusing since it has āG-Portā in the title, which hints at Gremsy, so it could be a Gremsy cloneā¦ but the Gremsy GPort is a hardware addon, not their UART protocol. Youāll have to order one to find out I guess.
I may well do that. As we speak Im drawing it up in cad to see if it will fit on my plane.
Let us know how it turns out
Ive knocked up a rough idea for a retract mechanism for this gimbal.
Question arising from the fact Ive had a fair few radio failsafes recently.-
After a ādo land startā I would think its a good idea to retract the gimbal but I only see the ādo mount controlā which will position the gimbal axis, I dont see a mount retract option. I guess I could to a set servo but shouldnāt there be a neater way?
I dont see much info on setting mount retract servo limits etc.
EDIT- I just found everything I needed -
https://ardupilot.org/copter/docs/common-landing-gear.html
Hi Vince!, could you share the files for 3d printing?
Iāve changed design about 5 times since I posted but when itās finalised Iāll share. Itās more simple now than picture.
Great! Thks Vince! iāll be looking for it!
Design is coming along but the HS81 servo is not strong enough. It needs a push to leave the lowered position. Looking for a stronger one, hopefully the same size.
Looks great! also heavy copared with the gimbal if i wanted to rise the gimbal to clear the bottom plate?
Great!!! could you share the 3d files? and also the metal parts where to find it?
All you need should be in description.
Thks!!! i will try to reunite all the missing parts, also what software did yo use for design? i need to make some mods to it
Best Regards!
I used Solidworks. Will upload the solidworks files it it helps.
