Help regarding camera for mapping platform on Skywalker X8
Hello, I am building a skywalker X8 for mapping purpose. I have decided to use Sony a6000 for the purpose. I want help regarding selection of the lens for sony a6000. Which lens would be best for this purpose. I have a 16mm lens. Is that okay?
Also I want to mount camera using 3d printed mount. Is there any stl file for the mount?
Thanks for your time.
Cheers!
Shubham Thakur
I found the 16mm pancake lens very difficult to focus, especially for hi res imagery. I use a 19mm lens which works well. It’s much longer however, so you need to build a good cradle for it.
Iam
Shubham_Thakur
March 7
lens. Is that okay?
Cheers!
Shubham Thakur
Agree ! 20mm pancake is far away better.
@iskess , I guess you are talking about sigma one.
If you want to keep this focal, you need a more expensive an heavier lens like voigtlander 15mm …
Yes, the Sigma 19 works well, not too pricey.
Iam
kikislater
Sylvain POULAIN
March 8
Thank you @kikislater @iskess for help
Cheers!
Shubham Thakur
The 19 mm and 20 mm lenses are not available in my region.
Is there any other alternative for them.
Also,
What effects will I have on m outputs if I use lens with focal length greater than 20?
What were the conditions you faced problems when using 16mm lens
Thanks
Shubham Thakur
hello @kikislater @iskess
I have a 16-50 lens. Will that work for mapping?
Can you help choose between sigma 19mm, pancake 16mm and pancake 20 mm?
thanks
first pancake 20 mm , second sigma 19mm (only for the size)…pancake 16 mm, I would try to avoid it.
