I am currently developing a physics simulator, and am currently meaning to use the JSON interface. I tested the UDP connection and I seem to recieve the PWM values from the SITL alright. the pwm values in the SITL are configured to [1100:1900] with trim set at 1500. I am confused with the logics behind the pwm and it’s values and would appreciate any answer/opinion regarding my questions:
does trim=1500 mean that at 1500 the motor will not recieve voltage? if so, what do [1000:1500] values correspond to?
is the mavlink SERVO_OUTPUT_RAW message taking in account the trim? is it the same as the message sent in the SITL interface?
are the RC channel parameters linked to the servo PWM params?
I’m new to the field and have struggled to find answers online, would appreciate any help, thanks!
