trying manual pitch tune 3 inch cinewhoop
firmware version stable 4.3.2
drone sliding all directions and not complete 100% tune
in full charged 2300mah battery
I trying taking stabilize flights try autotrim but not work
Are you saying the copter is not holding position?
You have no GPS unit (or Optical Flow sensor) detected or working - it is impossible to hold position without one.
You are in Stabilise mode, so the copter will move with the wind or any disturbance.
You will also need to test in AltHold , but Loiter will need a working GPS unit or some other position source.
You can improve the performance in all modes by connecting to MissionPlanner, got to set up, Mandatory… Accel Calibration
Carefully level the entire copter, then press the Calibrate Level button
Also set all of these:
BATT_FS_CRT_ACT,1
BATT_FS_LOW_ACT,2 or 3
BATT_LOW_VOLT,14.4
INS_ACCEL_FILTER,10
INS_GYRO_FILTER,75
INS_HNTCH_OPTS,0
INS_HNTCH_REF,1
