Good friends.
This time I come to you to see if you can help me with the problem I have.
I keep three APM 2.8, two without compass and the other without the., But the irony of the case is that none of the APM identifies the external compass.
I have three GPS two neo M7 and one neo M8.
What I have done
- Installation of firmware AR 2.50 AP3.3AC3.2.1
- I have tried removing the winged Jumper from the gps and placing it in the top one of the top
- I have placed the compass connector in the port below the GPS and in i2c
- Format the computer by installing an operating system inferior to the one it had (w10 to w8.1)
- I have used the mission planner MissionPlanner-1.3.30, MissionPlanner-1.3.41, MissionPlanner-1.3.42
- Verification of the continuity of the GPS and Compass cables to discard the cables.
- Validate the connection of the cables are the correct one of the APM, to the GPS
- The two APMs used in advance have all the data deleted (Full parameter list / reset to Default)
- I have connected the two GPS M7 and M8 to u-centersetup_v8.13 and send values, grab several satellites
Two of the t is APM worked fine but when updating the mission planner to its latest version all problems started.
Initially I thought it would be the APM that had been damaged but I bought one together with a new GPS and the problems persist with the new equipment.
I hope you can help me identify what happens with my planner missions
Best regards.
Buenas amigos.
En esta ocasión acudo a ustedes para ver si me pueden ayudar con el problema que tengo.
Mantengo tres APM 2.8, dos sin compass y el otro sin el., pero lo irónico del caso es que ninguna de las APM identifica el compass externo.
Tengo tres GPS dos neo M7 y un neo M8 .
Que he realizado
- Instalación del firmware AR 2.50 AP3.3AC3.2.1
- He probado quitando el Jumper alado del gps y colocándolo en el primero de la parte superior
- He colocado el conector del compass en el puerto debajo del GPS y en i2c
- Formatee el computador instalándole un sistema operativo inferior al que tenia ( w10 a w8.1 )
- He utilizado el misión planner MissionPlanner-1.3.30, MissionPlanner-1.3.41, MissionPlanner-1.3.42
- Verificación de la continuidad de los cables del GPS y Compás para descartar que sean los cables.
- Validar la conexión de los cables sean la correcta de la APM, al GPS
- Los dos APM utilizados con antelación se les borro todos los datos ( Full parameter list / reset to Default )
- He conectado los dos GPS M7 y M8 al u-centersetup_v8.13 y manda valores, agarra varios satelites
Dos de los t es APM funcionaron bien pero al actualizar el mission Planner a su última versión empezaron todos los problemas.
Inicialmente pensé que sería la APM que se había dañado pero he comprado una conjuntamente con un nuevo GPS y los problemas persisten con el nuevo equipo.
Espero que me puedan ayudar a identificar que pasa con mis misiones planner
Saludos cordiales.
