in my case t drone m15000 frame that makes head wind more vibration but tail wind drone will stable and ekf issues tunning its following graphs frame wise two propplers have diflection in cm in nose of drone any solution on that case
If props bend heavily under load, get better/stiffer props.
not a prop bend motor mount difliction on there drone if any possiblites to make drone propper fly
If the motor mount bends then you need a better/stiffer frame. Motors must not bend!
Read section 1.1 of this document:
