I’ve been trying to connect a servo motor to the ardupilot for my project.
However, i’m having some issues, as seen in the picture, I’ve connected the signal wire from the servo to A11 and the other 2 wires to a battery pack (2X AA 1.5V)- is that the issue? (This is just a small servo for testing, the actual servo to be used in the project needs 7.4V and is accounted for with a bigger battery)
In mission planner, I’ve set the “Do_set_servo” for 11 and 10 to 0 as the ardurover guide suggests (tried both slots)
Then, in the servo tab, trying to test for movement there is no response.
Any help is appreciated
Thanks
