So from your source tree run libraries/AP_HAL_ChibiOS/hwdef/scripts/convert_betaflight_unified.py on the config and that will give you a reasonable starting point for the hwdef
Awesome. Thank you.
Just so Iām clear, by Betaflight configuration you are referring to the results of āsave backupā from the configurator?
I donāt have to choose a specific branch within Ardupilot because the BF configuration contains enough info?
No there is not enough info in the dump - you need an actual unified config of this kind - GitHub - betaflight/unified-targets: Target configurations for Betaflight Unified Targets - I couldnāt see the config in there, but maybe I didnāt look hard enough
Use the master branch
Ok. Iāll work on this tomorrow and report back. Thanks again for all your help and guidance.
I ran the instsall prereqs but still get the same error about arm-none-eabi-ar when I run:
./waf configure --board CubeBlack
Update: It works after a linux restart
I get this error when I try to convert the Betaflight config. BTW I donāt know what āboard IDā is that Iām prompted for so I entered the BF config filename.
wam@wam-ROG-Strix-G533ZW-G533ZW:~/ardupilot$ libraries/AP_HAL_ChibiOS/hwdef/scripts/convert_betaflight_unified.py BEFH-BETAFPVF405.config Board id? BEFH-BETAFPVF405.config define: USE_ACC define: USE_ACC_SPI_MPU6000 define: USE_GYRO define: USE_GYRO_SPI_MPU6000 define: USE_GYRO_SPI_ICM42688P define: USE_ACC_SPI_ICM42688P define: USE_ACCGYRO_BMI270 define: USE_BARO define: USE_BARO_SPI_BMP280 define: USE_FLASH define: USE_FLASH_W25Q128FV define: USE_MAX7456 resource: 1 PB4 BEEPER BEEPER resource: 1 PB0 MOTOR MOTOR resource: 2 PB1 MOTOR MOTOR resource: 3 PA3 MOTOR MOTOR resource: 4 PA2 MOTOR MOTOR resource: 5 PC8 MOTOR MOTOR resource: 6 PA8 MOTOR MOTOR resource: 1 PB8 PPM PPM resource: 1 PC9 SONAR SONAR_TRIGGER resource: 1 PA8 SONAR SONAR_ECHO resource: 1 PB6 LED LED_STRIP resource: 1 PA9 SERIAL SERIAL_TX resource: 3 PB10 SERIAL SERIAL_TX resource: 4 PA0 SERIAL SERIAL_TX resource: 6 PC6 SERIAL SERIAL_TX resource: 1 PA10 SERIAL SERIAL_RX resource: 3 PB11 SERIAL SERIAL_RX resource: 4 PA1 SERIAL SERIAL_RX resource: 5 PD2 SERIAL SERIAL_RX resource: 6 PC7 SERIAL SERIAL_RX resource: 3 PC9 INVERTER INVERTER resource: 6 PC8 INVERTER INVERTER resource: 1 PB5 LED LED resource: 1 PA5 SPI SPI_SCK resource: 2 PB13 SPI SPI_SCK resource: 3 PC10 SPI SPI_SCK resource: 1 PA6 SPI SPI_MISO resource: 2 PB14 SPI SPI_MISO resource: 3 PC11 SPI SPI_MISO resource: 1 PA7 SPI SPI_MOSI resource: 2 PB15 SPI SPI_MOSI resource: 3 PC12 SPI SPI_MOSI resource: 1 PB8 ESCSERIAL ESCSERIAL resource: 1 PC2 ADC ADC_BATT resource: 1 PC0 ADC ADC_RSSI resource: 1 PC1 ADC ADC_CURR resource: 1 PB3 BARO BARO_CS resource: 1 PB12 SDCARD SDCARD_CS resource: 1 PB7 SDCARD SDCARD_DETECT resource: 1 PB12 FLASH FLASH_CS resource: 1 PA15 OSD OSD_CS resource: 1 PC4 GYRO GYRO_EXTI resource: 1 PA4 GYRO GYRO_CS resource: 1 PC5 USB USB_DETECT timer: PB8 TIM10 CH1 timer: PC8 TIM8 CH3 timer: PB0 TIM3 CH3 timer: PB1 TIM3 CH4 timer: PA3 TIM2 CH4 timer: PA2 TIM2 CH3 timer: PB6 TIM4 CH1 timer: PA8 TIM1 CH1 timer: PA9 TIM1 CH2 timer: PA10 TIM1 CH3 feature: RX_SERIAL feature: AIRMODE feature: LED_STRIP feature: OSD settings: mag_bustype I2C settings: mag_i2c_device 2 settings: mag_hardware NONE settings: baro_spi_device 3 settings: baro_hardware NONE settings: serialrx_provider SBUS settings: adc_device 2 settings: blackbox_device SPIFLASH settings: dshot_idle_value 450 settings: dshot_burst ON settings: motor_pwm_protocol DSHOT600 settings: motor_poles 12 settings: current_meter ADC settings: battery_meter ADC settings: beeper_inversion ON settings: beeper_od OFF settings: yaw_motors_reversed ON settings: sdcard_detect_inverted ON settings: sdcard_mode SPI settings: sdcard_spi_bus 2 settings: system_hse_mhz 8 settings: vtx_band 5 settings: vtx_channel 8 settings: vtx_power 1 settings: vtx_freq 5917 settings: max7456_spi_bus 3 settings: dashboard_i2c_bus 2 settings: flash_spi_bus 2 settings: gyro_1_bustype SPI settings: gyro_1_spibus 1 settings: gyro_1_sensor_align CW270 settings: gyro_1_align_yaw 2700 settings: gyro_2_spibus 1 Traceback (most recent call last): File "/home/wam/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/scripts/convert_betaflight_unified.py", line 500, in <module> convert_file(fname, board_id) File "/home/wam/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/scripts/convert_betaflight_unified.py", line 319, in convert_file ''' % (get_ADC1_chan(mcu, adc[1]), int(settings['ibata_scale']) * 59.5 / 168 )) # scale taken from KakuteH7 KeyError: 'ibata_scale'
board id is a number that the bootloader protocol uses unique to each board - just pick one for now, e.g. 1200
looks like the battery info is missing from the config - try adding a fake one from another board
Thank you for that.
That completed without any error messages but I donāt see a folder under Build like when I built the example?
you still have some work to do - you should end up with hwdef.dat and hwdef-bl.dat in the current directory. You then need to create a directory in libraries/AP_HAL_ChibiOS/hwdef with an appropriate name and copy them there. Then try building using that name
Ok, now I have a folder with the name I gave the board (BetaFPV-F405AIO) that contains a bin folder with arducopter.apj and arducopter.bin. Those are my targets right? Did it also build the _bl version?
You will need to build the bootloader to get that. Run ./Tools/scripts/build_bootloaders.py BetaFPV-F405AIO to get that
Awesome thanks so much for all of your help.
What should I look for (other than obvious error messages etc) when I load the firmware into the board?
I loaded the hex file with the STM32Cube programmer. The board shows up as Ardupilot on USB as COM4, but mission planner is unable to connect - no heartbeat packets
https://ardupilot.org/dev/docs/porting.html
youāll probably need to try removing stuff until you can get something that boots. I recommend you use mavproxy for connecting since then you can see any debug messages
This slightly presupposes that the config you used is the right one - if its the wrong one with the wrong pin definitions then that would also cause this kind of problem
I let Betaflight auto-detect the board and then selected that as the base.
Should I have reset the environment (clean dist) after the first build but before the _BL version?
Not sure. If you build the bootloader you will then need to reconfigure and rebuild for the regular firmware
I suggest you start putting your changes up as a PR so that we can see what you have so far
Ok.i will read about how to do that later today or tomorrow.
