Andy thank you.
Ekf lane switching can be due to these problems you are telling me?
The copter is a 20 inch prop, 10 kg, so not small but not huge.
So what can i try?
Windows = 256
ins opts = 2
fft max = 300
Something else?
Lane switching makes me a bit nervous. Is it possible that the copter was flying a bit worse because of the filter acting weird?
p.s. tonight will carefully read the other thread on fft.
The lane switch is because your positional down innovations are high. I can’t quite figure out what is causing that. It’s possible that additional noise introduced by poor notch tracking is introducing this. Were you flying with the throttle based notch before?
GPS is in RTK fixed while barometer i am using internal, maybe should set gps as primary source, anyway never did it before i enabled notch, maybe just a coincidence.
Thanks Andy, i have read it. Main difference is that mine flies pretty well without notch and is decently tuned. Mine has probably more than 1000 hours flight time (it doesn’t show on param because we recently switched to cube orange.
Another thing we changed is the cover of the drone, it is much smaller now and maybe the fan creates some funny air flows inside the frame and the internal barometer we use isn’t happy.
@andyp1per looking at the barometer in the logs there is definitely something wrong and lane switching happens at the exact moment the baro has a glitch.
I don’t know if the FFT enabling can have anything to do with the barometer stop working.
Just checked the last log before the one with FFT enabled and barometer was working correctly. Probably has nothing to do with it but i tought it was better mention it to you in case it rings a bell
