Harmonic notch filter, TUNING
@xfacta Hi sir , im developing a drone with 2.7kg takeoff weight,t motor with 13.6ah battery with 14 inch propeller , when i tried to autotune its always showing as autotune failed ,tune manually ,and i don’t know how to set correct harmonic notch filer , i have attached the logs , please help me out in correct tuning of the drone
https://drive.google.com/drive/folders/1MRi36LOqsESRwWfZgV1CCxbh_zFINRSI?usp=drive_link
Go here and get to work: The Configurator
And when posting logs post one (1) or give a description of each. No one is going to go thru a bunch of logs looking for what you are reporting.
Now ,its updated sir
Then when you have worked your way thru the configurator and still have a question post it.
We need a .zip file with the files created by the configurator as a proof that you actually did what you said and showing us the reasoning behind the decisions you made while configuring the vehicle.
By doing this you will learn something and your vehicle will work a lot better.
