Hardware Safety Switch will not engage (USE CAN PORT)
I have a Hexa X copter built with Cube Orabge and most current version of Arducopter. So I use CAN1 and CAN 2 port for Dual GPS.
And GPS_TYPE is 9.UAVCAN
GPS_TYPE2 is 9.UAVCAN
Everything is great, but I can’t arm. The HARDWARE SAFETY SWITCH will not engage when pushed.
This is my parameters.
HEXA X.param (18.9 KB)
THANKS
Do you have an hardware switch connected?? How?? Where?
No I haven’t switch connected. I use HERE2 GPS.
I use Here3 and they do not have a safety switch.
Did you connect the safety switch cable from one of the Here 2 to the flight controller?
No cable, no signal!!!
I am using beaglebone blue with CAN NEO 3 Pro GPS which has hardware safety switch using arducopter. Is it possible to enable that switch for arm/Disarm the motors
I want to know where close the hardware safety switch,which?
