I’m having an issue with a Matek H743-Wing V2 not detecting any GPS module. I’ve tested with two boards both on 4.1.2 with a M9N-5883 (worked on my F405-Wing when I tested) and a known working M8Q-5883 that also works on the F405. I’ve tested on serial 3/4/7 and all have the same issue.
Any idea what options might I need to tweak or mess around with?
Default settings (38 for baud, no options, serial protocol 5) on serial 3, 4 and for fun I also tried on 7. I toyed around with GPS_DRV_OPTIONS = 4 and also 5 but no difference.
Are you aware of the different serial port naming of the H743 board?
Different to the Matek F405-Wing here the ArduPilot port numbers does not match with the port names on the board.
More details can be found here: MATEK H743 docs
Scroll all the way down to find the info you may interested in.
