using APM with 4in 1 ESC’s (qbrian) on a HJ_H8 . power supply Bec and wiring is soldered … Fc is nearly installed . im am at the point of , tuning the esc’s . but next is the wiring … i need help with connecting the two esc’s to the FC? does the anyone know the wiring setup using 4in one esc’?? with / without hub
and any input (headsup) issues please let me know .! i hear that the props need to be different pitches because of rotor wash ?
HELP
That will get Them connected in the correct order. Then check each motor is spinning in the right direction, clockwise or anti-clockwise as required just swap any of the three leads to change spin direction. Then lastly make sure the props are clockwise or anti-clockwise type to match as well. Put them on the right way up with the embossed numbers facing up.
Sorry to take so long to get back to you.
