Hi everyone,
I got a “GY-NEO6MV2 GPS Module” that works fine when it’s connected to a “USB to UART Bridge”, (receives signal from more than 16 satellites and fixes on 3D mode in less than 30 seconds in cold start and less than 5 seconds in hot start), but when I connect it to the Ardupilot boards, it says: “GPS: No GPS”.
I tried it on 2 different boards (“Speedy Bee F4 V3” and “Omnibus F4 Nano V6.1”), and the results are the same: “GPS: No GPS”.
I tried different settings on either Ardupilot boards or the “GPS module”, also I checked the wiring and baud rate several times, but couldn’t get it to work.
Any suggestions?
Thanks
P.S. both Ardupilot boards work fine with a BN-880 GPS Module.
